Coil Spring Perch HELP PLEASE
I have a 78 F150 4x4 and the front drivers side frame is 1" lower than the passengers side. The frame at the rear of the truck is the same height on both sides. I have it stripped down with the axles under it and no motor in it at this time. Before I took it all the way down I also noticed the 1" lower frame. What would be the issue, if any, and is there a coil spring perch made to put under the coil to raise it an inch? I would just put it under the drivers side to try and raise it closer to the passenger side. Any other ideas are certainly welcome. Thanks.
x_man586
01-03-2014 09:10 PM
my91stealth
12-19-2010 07:30 PM
SEAN'S SLEEPER
04-12-2010 09:53 AM
classyfish
07-19-2002 10:46 AM
