Lower intake service-4.2L
I've a '97 4.2 stripped down to long block (heads still on). Replacing all gaskets and seals. My question is what is the proper service on the butterfly (throttle plates) in the lower intake manifold? I've pressure washed and cleaned the egr orifices in the other ports and the manual just says have a Ford dealer service the throttle plates and, yes, I'm sure there's a acronym for those parts I just don't remember what it is. Should I be conserned or just make sure all the shafts rotate and just put it back together? This is a used engine that I'm trying to make sure of few oil leaks as possible, just need to get it installed and running "soon". bl2009
You might find these bushings somewhere else cheaper in price, but, DO replace them!
http://www.ebay.com/itm/NEW-Ford-IMRC-Bushings-Intake-Manifold-Runner-Control-Retainer-Clips-4-OEM-/231452378684?fits=Make%3AFord
artfd
3.8 & 4.2L V6
01-20-2012 12:44 AM
