EBC brake pads
#31
Brakes caliper rebuild kits are available for a very low price. I thought they'd be a very smart choice because of the simplicity of a caliper. But when me and my friend, both fully capable and experienced technicians, rebuilt mine - apparently we failed somehow.
So I conclude there must be "more to it" and I'll just replace brake calipers from now on.
I still have caliper rebuild kits for the rears... Sealed bags if anyone wants them.
Having said that, some of these "rebuild suppliers" are sketchy as all he!!
Not all calipers are salvageable.
What went wrong ? did they leak? did you hone and install new pistons or just change the o-rings?
#32
I fully agree with your first paragraph. I guess there was a misunderstanding somewhere. Sorry about that.
However your second paragraph seems to contradict your first. Yes I do believe high-performance brakes are excellent for a truck. That's why I buy them. The sheer power of deceleration from my Powerstop brakes is/was phenomenal.
All it takes is one "close call" to fully justify the extra money. Have you ever had a vehicle crash that was your fault? I have. And I've had near misses as well.
Imagine if you rear-end crash somebody… Imagine yourself in that position and then imagine if an angel of the Lord appeared and tells you that it could've been prevented for $200…
If there was such a big difference, you would have felt it.
I think you fell into "new is better than old" trap.
#33
I got Powerstop brakes 23 months ago and they were awesome: except they pulled left due to my bad caliper.
I drove it that way (procrastinating) for about 15months and then during an oil change/tire rotate they saw the LF pads were nearly metal to metal so they slapped on a set of Ford crap.
During the next few months I forgot about the Ford pads but I noticed they didn't have the usual high performance torque. I remembered the Powerstop upgrade was approximately Aug/Sept 2014, so my mind assumed the Powerstop pads faded their torque due to wear.
Yes I completely forgot about the Ford pads. That's why I recently resurrected this thread- to be honest and full disclosure. i had been telling everyone (including myself) that my Powerstop pads and rotors had almost 100,000miles on them.
#35
#36
My greens went out in about 6 months on my work van with slotted rotors. I think I have a caliper hanging but I don't have a pull while driving. I also have the right rear giving an issue and think it may be throwing the van while braking and causing undue wear on the left front or possibly the caliper on the right front being weak.
Just noticed the noise today and the inside pad was metal on metal and the outside wasn't far from it but enough that the metal piece that makes the noise wasn't touching yet. I'll be changing the other side tomorrow and check wear then. Was too late to get both tonight but had to get that one pad changed. When pressing in the piston it seemed smooth and I always grease up the sliders. I've got to get that rear drum loose to change the rears.
scooterspal
24
02-11-2012 05:15 AM
JohnPeter
03-12-2009 02:52 PM
