F350 sank in Harbor, Hydrolocked. Advice needed.
#31
#32
I've used many boat ramps and I saw some were the ramp so so slippery due to alge the rate of incline once the truck got going it would not of stopped.. even with the brakes on or gassing it in 2 wd. I always used 4x4 to back down and launch or retrieve.
And hasn't Fla had a huge Alge problem? ramp must of been aweful to stop on.
#33
#35
Thanks for all the advice, I do appreciate it. Had I know the amount of work just to get it to this point. I would have sold it for salvage. But, once committed, I am determined to get this to the best state I can.
So latest update....
After cleaning charge air cooler and craning engine minus injectors to get the 2nf batch of water out. I replaced injectors and (after a couple of diesel leaks for not tightening the high pressure rails enough).... engine burst into life. ran shakily at first then improved as the minutes passed. exhaust ejected some brown water from its dunking.
I ran a relative compression test, cylinder 6 was 4% off, Ran it again after 15 minutes running and it was down to 2%. Others were all 0%. I'm hoping that after some driving it will even out even more (had that with one of my flooded mercedes, after 500 miles all compression was back to normal, I'm guessing after rings were properly loosened and lubed up.
No Check Engine light and engine sounds great.
So the biggest hurdle seems to be over. now onto the small print. The turbo does not seem to be working. I only had this truck a few weeks before dunking it, but i seem to recall the turbo needle went up if you gave it gas and increased RPM even at idle. Can someone confirm this please? No errors on IDS related to turbo, I know nothing about turbo so would appreciate any pointers here. I do have another unit sitting in the donor truck(glad I bought that donor truck, I have a full set of parts needed to cover everything, just go and unbolt as needed). If needed I will swap them out, looks a bit of a PITA to get to but will cure it if all else fails.
After the turbo, there are a few errors in IDS that concern me. Would appreciate any advice on zeroing in on these. I have put pics of errors below
1. PCM Generator B control circuit.
I read that f350 has 2 alternators, does this point to one of those, or possible fuse?
2. IPC External Trip Switch Circuit (circuit open)
I have no idea what this is, google and service manual did not shed any light either. Any suggestions?
3. TCM Power relay control circuit open
4. TCM Actuator Supply Voltage B Circuit Open
Is this related to the generator B control circuit above. (note transmission does go into reverse and drive, have change fluids but not moved truck yet due to the lack of brakes :-) )
I'd be very grateful for any tips on the turbo or the 4 errors above. If and when this project gets finished it may just help someone else who drives the beloved into the sea, or it may encourage to sell it quick like I should have done if I'd had any sense.
#36
#37
#39
#40
#41
#42
#43
Good job sir .
I have always felt, if you have the patience , and proper tools, there is no reason these fresh water flood damaged vehicles , could not be brought back to life.
Probably the largest drawback , is the Car fax , and Title declaring flood damage , keeps people from buying an otherwise excellent vehicle.
I buy and sell rigs that have mechanical issues , and have stayed away from any that have salvage or rebuilt titles , because no matter how nice they are , and if the damage was minor , people try to beat me up on the price.
Heck , I have a very nice tacoma presently , no wrecks or damage ever, had cracked cylinder heads, which the 3.4 , is known for , that has 270.000 miles , and people are still a pain in the but, even tho Toyota followers know , these trucks with this engine are like our Super Duty's , and will run forever.
Keep up the great work, and don't let some discourage you .
#45
Have solve the generator B circuit problem.
After tracing all the wires I saw that the engine harness (which I had replaced) had a blanked plug over the wire that connected the the 2nd alternator. I assume the harness came from a single alternator model hencle the blanking plug. I removed the blanking plug, connected it to the other similar looking plug and the error went away
Turbo does not seem to be working, could be fouled up. I know nothing about turbos, are these serviceable??
I can swap it out with the one of the donor truck, will just devalue the donor a little more
