Broken therostat housing bolts
I took the fan off with an air chisel though. I just hit the end of the nut (it screws on the water pump like any normal bolt out there, it's not a reverse threaded bolt) with my air chisel until it broke loose. I did mess the nut up pretty bad on the outside, but I got it off and it went back on perfectly fine!
Once the fan is off, there really isn't anything else tricky to get the water pump off.
My trick for fan removal is to take the belt off, clamp a vise grip on the lip on the back of the fan pulley, then use a large channel lock, it's a heck of a better way then destroying your fan nut with an air chisel..... turn the nut the same direction the fan turns normally. When reassembling start the fan nut onto new pulley and then spin the fan till tight, I prefer to use the channel lock again to make sure it's tight.
You also might need a 10mm deep well socket for the water pump bolts.
Thanks man yea I'm still up in the air weather I wanna try air chisel or the ford tools? Anyone know the exact size of that but? I have rear 28mm 24 and a few others online just don't wanna make 10 trips to the store. Also when placing the pump back on should the bolts be tightened in a cross pattern? Thanks in advance Kyle
I would tighten it up as much as possible. There have been a few cases on here when the engine was shut down the fan spun off and went through the radiator, not a good thing.
#28
You can rent fan clutch wrenches at the FLAPS.
#29
Replacing the actual pump is very straight forward. If you can get the fan off, you are mostly there. I just did one this morning. $150 or so for the pump (parts store) with new lower elbow. Comes with new o-ring/gasket at the block, too. Once fan is out of the way, it's just some bolts and surface prep away from going back on. Not sure penetrating oil would do any good as most of the bolts are long, way into the block. The issue you had at the housing is it's steel bolts in an alumin housing. The bolts that hold the pump on go into the block. I can't say it's impossible to break those bolts, it's just not very likely. We typically don't have an issue with those, even with all the corrosion we see here.
Good luck.
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
#30
Good luck.
Good luck.
Right hand thread means just spin it off lefty lost my righty tightly while looking at the front of the truck right?
