4 Inch Exhaust fit
Mine is 3" halfway down, then flares to 3.5" and 4" as it goes horizontal. I've got no muff or kitty due to no emissions in my county and a permanent exemption cert from the dealer who sold it new. Mine is aFe and other than a little work on the firewall seam, was easy to install. Before you go cutting on the cobra head, unbolt it, pull it away from the turbo and tape off the opening, then reinstall and cut. Otherwise you could get shavings in the turbo.
Diamond Eye makes a quality kit. Turbo back, cat back, aluminized, stainless, 3" dp to 4"..., 3" dp to 5"......... Riff Raff sells them. That's where I bought my turbo back 5" stainless kit. Fit very well. Easy install.. I bought the stainless band clamps from my local NAPA..... And you just can't beat Riff Raff Diesel!
I believe this to be correct and also the reason why most 4" and 5" "full exhaust systems all start with a 3" down pipe. Much bigger won't fit down between the firewall and the exhaust up pipes and the transmission, much less make the bend from vertical to horizontal without more than just bending over the pinch weld.
Adding that my recent FloPro install experience was more difficult than it should have been.
The provided front hanger was useless and I fabbed one using the old catalytic converter hangers, the middle one on the muffler was bent in place but doesn't look right, and the rear hanger was nowhere close to working without some creativity.
The turbo flange was noticeably smaller though the pipe was the correct diameter. I did not trust it and cut it off and had the factory flange welded on.
Just my experience...
#28
