Upgrade your braking power for a $100? Interested?
If the cast iron MC is filled correctly, the fluid is about 1/4-inch from the top. Other than the seal on the underside of the lid, air is also occupying this space.
The molecules of the brake fluid are too large to seep through the pores of the rubber seal on the MC lid or through the rubber jacketing of the flexible brake hoses but, moisture isn't. Its molecules are small enough to eventually penetrate these soft items. This is how moisture gets into the brake system (other than taking the lid off the MC) and is why the brake fluid should be regularly changed out for fresh fluid. This would be about every 18 to 24 months that the brake fluid should be changed.
Rust is an *oxidation* process. Water and iron can be in contact for millenia without rusting if there is no Oxygen.
This is for the silicone fluids recommended for aluminum MCs.
The problem with water in a brake system is that it is heavier than brake fluid. So it tends to flow down to the lowest point in the system. Right into the slave cylinders.
Then one hits the brakes hard enough that the fluid and the cylinder get above the boiling point of the water. It *can* boil or flash into steam. Which releases oxygen.
The other problem, not too much of one in Southern Arizona is freezing.
One doesn't usually have enough water in the system to cause expansion problems but I have heard of someone who claimed that the water froze his pucks in place.
But all one has to do is just maintain the brake system properly.
I don't remember ever having water in my hydraulic system and I never saw rust.
One of the benefits of living in the desert.
The brake valve is for an '84-'86 Ford F150/Bronco (E4TZ-2B257-B). It was an OEM/NOS item I bought off ebay and it was still in the Ford logo box when I got it.
I didn't see it mentioned if CraigerF100 is running this setup with all-wheel drums or, if his truck has discs front/drums rear. I also didn't see it mentioned if the booster used in the example is a 7" diameter unit or, if it's an 8" booster.
If the brakes consists of all-wheel drums, you could get away with running a 7" diameter booster. If you're running discs on the front, a 7" booster is going to lead to disappointing results. For discs on the front, at minimum, you need an 8" diameter booster and a good 18"-20" Hg signal on the booster for it to operate at its maximum potential.
Standard sized SAE inverted flare brake fittings for 3/16" diameter tubing are 3/8"-24 (FYI metric 4.75mm brake tubing is also the same diameter as 3/16" tubing). 3/8"-24 fittings are available individually through parts stores.
You can also get new direct-connection flare nut line fittings in 7/16"-24, 1/2"-20 and 9/16"-18 through Classic Tube (eliminates the need for ugly line fitting port adapters). Parts stores generally do not carry these specialty sized fittings for 3/16" brake tubing.
Left to right: 9/16"-18 inverted flare fitting, 1/2"-20 and 7/16"-24.
The 7/16"-24 fitting is Classic Tube part number ST8006.
1/2"-20 is p/n ST8007.
9/16"-18 is p/n ST8010.
These are OEM type steel fittings. They are also available in stainless steel as well.
If you were running a 'modern' MC with metric bubble flare ports, where one port is an M10 x 1.0 and the other was an M12 x 1.0, the part number for the M10 X 1.0 fitting is ST8036. The M12 x 1.0 fitting is ST8040.
This way was me on a budget trying to get quality brakes that don't brake the bank. So possibly some modifications required. If the possible mods. Stated above don't scare u? Then maybe it might work a try. 👍
Awesome job and write up. I love using the modern parts like this to make our trucks drive and perform better than stock. One of the big benefits I see from this (at least here in the land of humidity where I'm at) is that the aluminum MC is not going to rust internally and contaminate the system as the cast iron cylinders do.
I just swapped an aluminum MC from a junkyard Expedition onto an old F250 4x4 I have a few months back and it literally bolted on including the lines. I was experimenting because I kept going thru the cast iron cylinders about once a year. I think it was 15 or 20 bucks and it's working out really good so far.
Yeah remand MC aren't what they used to be.
Not a bad idea
Lol the thought has crossed my mind. With the modifications already done and parts mated. But I've pondered how I'd do free shipping and if I'd have to warrenty it if at all. $200 plus shipping would be the price I'm sure. I'd make only $50-100 depending on how many affordable parts I can buy in one sitting.
#28
An 8" dual diaphragm
Ultraranger knows his stuff for sure. I'd trust any advice he gives. I personally haven't found any true evidence online supporting booster size or number of diaphragms working better or worse. Besides what's with in reason, you know common sense set ups.
Example:
Running a 7" single diaphragm booster on
A f350 or f600 4x4 dually crew cab you use for hauling and towing 8000lbs plus loads on the hwy... May not be smart lol
I went over kill on the booster just to play it safe.
Honestly, my opinion? A 7" dual diaphragm booster would be more then enough for our trucks. Especially what most of us use our trucks for today. Fun!
#30
Front disc rear drum
Example:
Example:
The booster is just a force multiplier. If the surface area of its diaphragm(s) don't have enough area, the brakes will not be effective at doing what they need to do --stop your vehicle within a reasonable distance.
