I'm confused on all the turbo stuff
Considering the cost of an E99 spider, use the parts you have and simply switch over to 3" plenums.
Down the road if you go to a bigger turbo you will be required to be at 3" any way.
If you do go bigger the 38r is your only performance bolt in, otherwise do it right and go to a t4 setup with a S369 sxe fmw super core.. They push as much as the small 4 series chargers, and spool much quicker. Go google and check them out!
#28
The other thing is measure the drivers manifold at the rear and compare to your truck. My firewall is too close to use the sd manifold. There are variations in these cabs that have been seen.
You will want to check yours before you get started.i had kicked around building a hybrid set of up pipes for obs manifolds to sd collector/turbo and doing a 38r. I prob should have just gone that route as it got a bit out of hand otherwise
