1997 f250 hd running ruff all at once
Filled up with diesel drove home ran good started it up in the morning drove about 5 miles and turned a corner and all at once started running really ruff,had no power acts like a fuel issue changed the fuel filter still runs the same no codes and ses light not on any ideas ?? Any help greatly appreciated
Thanks for the info how would you ohm the uvch
You ohm the pins on the valve cover gasket.
Pin layout is
GICIG
G - Glow Plug
I - Injector +
C - Injector -
Ohms between the G and block Ground should be 0.1 - 2.0 ohms.
Ohms between the I and C one at a time if one or more is > 4 ohms, it will point to the side's gasket connector or UVC harness being shorted.
Pin layout is
GICIG
G - Glow Plug
I - Injector +
C - Injector -
Pin layout is
GICIG
G - Glow Plug
I - Injector +
C - Injector -
Pin layout is
GICIG
G - Glow Plug
I - Injector +
C - Injector -
thanks
