Long bed -> Short bed, Cutting frame. Any one done this?
06-08-2016, 01:45 PM
06-08-2016, 01:46 PM
Quote:
Originally Posted by
Diesel_Brad
Straight, Z, whatever you want.
Then plate the inside
For anyone who says NOT to straight cut a frame, just look at a semi. They are ALL straight cut
x2 The fish plates are what really matters. Avoid sharp transitions at all costs.
Krewat
Is that bed liner made of 1/2" cold-rolled steel?
It was only loaded with a bobcat so the drop wasn't too far. Dropping cinderblocks off a roof would probably be different.
06-08-2016, 02:08 PM
Where are you located? I am doing an extension and could use the section you cut out.
06-08-2016, 06:59 PM
This is similar to going from indoor plumbing to an outhouse.
06-08-2016, 08:38 PM
Z cuts are the best way to make the cut; plain and simple.
Necessary? Nope. Best? Yep. Worth the trouble? Up to the guy holding the knife.
kjdungan
13
03-21-2011 09:00 PM
mfire138
01-09-2009 07:27 PM
mfire138
08-25-2008 12:46 PM
PowerAddict
1997 - 2003 F150
05-05-2008 11:58 PM
custom69
21
05-30-2005 04:41 PM
