lpop on the way out???
#31
#34
#35
#36
well
back at it
Truck ran great for the 1 hour long ride. next day started doing the same thing. Pulled the passenger side valve cover and air tested. had one injector top oring leaking. changed it and all the nipple cup orings. no leaking for about an hour. great.replace the original style standpipe with the updated one and new dummy plug. bottoned it back up took it for a ride. ran better than it ever has . roll into the throttle doing about 25-30 mph and suddenly I'm sideways. never done that before.
then crap. starts doing it again. icp starts dropping ipr goes up truck stalls. wait 20 seconds starts right back up.
if I floor it, it seems fine. I don't hold the pedal down long as it doesn't take long to get to 80 . icp and ipr are normal and no stalling for short high oil demand situations. It seems to do it on longer runs at 1800 rpms or higher. like the reservoir goes dry.
guess I'm taking it back apart.
back at it
#38
You are right something is else is going on
guess I don't see how the hpop could be failing when it's fine for short max output but can't keep up with long low output.
with the icp dropping off and the ipr maxing out, I don't see a fuel issue. any and all explanations for any of this is truly welcome as I am getting frustrated (as is my wife) spending the bulk of my week under the hood.
thanks
#39
You have the old style pump, standpipes and dummy plugs are the new updated versions. Did all the injector top seals and nipple cups o-rings and have no leaks?
No STC fitting and it's loosing power in the long pull, not short bursts? You can see the ICP drop off and IPR come on asking for more.... that sum it up?
#40
except I only replaced the injector orings that were leaking. after they were replaced I retested to confirm no leaking.
#41
#42
Blue spring done? Put a gauge on the fuel, you can borrow it from Advance or Auto Zone, but I don't think that's your issue. I say that because if it was fuel related, that wouldn't command higher ICP/ IPR.
But worth checking to make sure you don't have a restricted fuel line or something like that.
I'm thinking your HPOP is dying. Can you hit near 4000 psi with it or does it run out if steam before then?
#43
did the bb mod awhile ago. Don't think its a fuel issue either.
think the highest I ever saw was about 3600 for the icp.
mechanic friend I borrowed the scanner from thought hpop with the bubbling/gurgling from the oil filter housing.
#45
Seems like 90% of the time on these threads with that sound of the gurgle it's the HPOP, or in the case of a later build the STC.
