lpop on the way out???
4 years old. don't know what brand the mechanic installed. I was wet behind the ears to these motors, didn't know to specify.
bump
finally had time to get it into it this week.
shop air through the icp on the valve cover, 12 volts to the ipr. no air through the oil fill or breather or oil filter housing. a little bit of air through the turbo drain tube.
Haven't seen any info in 2 days of searching about air coming out of the turbo drain tube. I'm guessing the hpop is leaking out an oring???
please, I need opinions. thanks in advance
Do you have the early style of late style HPOP?
That will make a big difference. Early build, then very good chance it's bad, late build not so much........failures are rare. You have the wavy oil rails since the ICP in on the valve cover, but since it's an 04 might be the crossover engine with early HPOP.
It it's late build then you might have a bad STC.
any chime ins on air blowing out the turbo drain during air testing the hpop? Still haven't found anything online about it.
Don't be too shocked if the HPOP has gone south for the winter.I would suggest spending a little extra scratch and going with the Adrenaline pump.
At any rate you should not have air coming from the return line hole. How long did you leave the shop air on?
Lucky you, you have the early pump AND the dummy plugs.....oh well
I will retest it a few more times to make sure the only place is from the turbo drain.
Have you had the valve covers off? It won't hurt to take them off when doing the air test. With the covers on sometimes things can sound like something else or you might pick up something you would not have, it's up to you. I did an STC last month that I would have sworn was the dummies, R and R'd them only to air test it again, covers off, to find out it was the STC. Dummies were not trashed but really brittle, so it was time for them anyway but it was not the main problem. Truck would start hot prolonged crank most of the time, ran like a top, yet I pulled the fitting apart with my fingers after I took it out. I tested through the ICP as you are.
Have the dummy plugs been done that you know of? It's pretty cheap and easy fix.
My money is on the HPOP, odd are in your favor. It's possible the noise from the turbo drain is your HPOP and the noise is migrating to that spot.
#28
Leave it hooked up for 10 minutes or longer, no IPR activated. You will still backfeed air if there is a leak somewhere else. Remember you are checking for leaks on a 4000 psi system with shop air at what, 120 psi?
Have you had the valve covers off? It won't hurt to take them off when doing the air test. With the covers on sometimes things can sound like something else or you might pick up something you would not have, it's up to you. I did an STC last month that I would have sworn was the dummies, R and R'd them only to air test it again, covers off, to find out it was the STC. Truck would start hot prolonged crank most of the time, ran like a top, yet I pulled the fitting apart with my fingers after I took it out.
I haven't done the dummy plugs since I've owned it about 50k miles. might as well. Going to start a thread on the adrenaline pump, I havent found a lot online about long term use.
thanks Mike
#29
You will be glad you bought the Adrenaline, if I end up doing the kids truck again it will be that one.
You will need either a half inch ext or a 10mm allen to get the old dummies out. New will be a 12mm, 60 ft lbs torque once you get them in.
Don't over torque the valve covers, only 8 ft lbs or 96 inch lbs, in other words a little past snug. They can strip easily, fact is you prolly won't even be able to torque a few of the harder to reach bolts, don't worry about it. Some trucks are missing a bolt here or there and they don't leak from what I have been told.
Gaskets can be used again, just wipe them off good, inspect and use them again, master techs don't replace them either unless damaged
The stand pipes are up to you. You will likely buy the kit that has both, but many techs won't do them unless they are bad, and they seldom go bad. The passenger side stand pipe takes a little more effort, and since they rarely go bad they don't usually get replaced. Dieseltechron has some great videos on all that stuff.
#30
