Frank's 97 F250 ECSB intro & progress thread
Welp, wouldn't you know it, both up pipes are leaking! I can't believe I didn't notice this previously. It makes perfect sense too, the insulation against the firewall is all discolored.
I also noticed my exhaust manifolds are leaking at the rear cylinders as well. I guess I'll save that for another day.
I soaked the bolts with penetrating oil and I'll be picking up some new donuts on my way home from work today.
Thanks guys! I think I need new glasses...
Call riff raff get bellowed up pipes and a new y
As a truck I don't intend on using every day, I opted for buying a 25$ helicoil kit and repairing the threads, with great success too!
The Y pipe is back in, the Graphite/Mesh F17250 gaskets crushed real nice.
Fuel bowl/Fuel pump are back in and plumbed up.
Turbo/pedestal is back in and im finishing cranking down the exhaust flange bolts..they are very tricky to get to.
I'm hoping to have this truck fired up today..Finger's crossed it works and is leak free
It's alive!
..and leak free!
Rebuilt Fuel Bowl, Rebuilt Turbo, New Fuel pump, new intake hoses, new up pipe gaskets, EBPV gut/delete, 6637 intake. I am SO glad this thing runs after having it all apart. The up pipe gaskets were a massive pain in the ***.
Here's a quick video..
The next adventure will be sealing up the cab & around the windshield.. then the E4OD has to come out for a new TC and the TransGo Tugger kit.
..and leak free!
#28
It's clean because all the dirt/grime was exchanged to my clothes and body . took me a solid 20-24 hours to remove/rebuild/reinstall everything, including all the setbacks.
I did wipe everything down so i can chase down leaks easier.
I notice a small weep of oil from my HPOP.. unsure where exactly its coming from. It appears to be from the mounting surface.. I need to look into it further.
#29
