1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2006 Navigator driver's door panel removal
Old 05-20-2016, 07:35 PM
AGrayson84's Avatar
AGrayson84
AGrayson84 is offline
Hi guys, I need to replace the power mirror switch on my '06 Navigator and can't seem to find how the panel comes off. I removed the trims around the interior door lever, the Phillips screw that is recessed into the upper, outer edge of the door panel, and the two small hex screws at the bottom of the door. I've tried popping the bottom of the panel outward, and have tried sliding it up, but no joy. Can't seem to find a single set of instructions or a video in this anywhere in these Interwebz. Thanks in advance!
Old 05-20-2016, 09:10 PM
Action410's Avatar
Action410
Action410 is offline
I take you don't have a shop manual.
The shop manual states there are 2 bolts and 3 screws to remove the door panel. Then the panel needs to be lifted by pulling directly upward on the armrest to disengage panels clips.
>>>>>>Action
Old 05-20-2016, 09:30 PM
AGrayson84's Avatar
AGrayson84
>>>>>>Action
Thanks for the response! I sure don't. I've only had the truck for 3 weeks and I'm usually mechanically-inclined to do nearly anything without a shop manual these days... but maybe I need to one up!! Haha. I don't suppose what you saw mentions or shows where the bolts are, assuming they're not referring to the bottom hex screws as bolts? Thanks again!
Old 05-20-2016, 10:45 PM
Action410's Avatar
Action410
From memory
There are 2 fasterners on the bottom, one on the lagging edge. (opposite of the leading edge) And 2 in the center.
I will get to manual out in the am. (unless some one else chimes in)
>>>>>>>>>Action
Old 05-21-2016, 10:24 AM
alloro's Avatar
alloro
alloro is offline
Received 4,216 Likes on 2,447 Posts
Here are the FSM pages.
Old 05-24-2016, 09:37 AM
AGrayson84's Avatar
AGrayson84
Thanks for the help with this guys! I'm a big dummy... I didn't even see those two screws in the cubby that are under the armrest. In my defense, I was looking in the dark, and just didn't bring my head down low enough to see them the other night. Got the new switch in and all is good. Thanks again!!
KevVer
04-17-2013 11:10 PM
dafella
1997 - 2003 F150
02-11-2009 05:21 AM
kenwowski
2004 - 2008 F150
01-07-2008 07:17 AM
rhw
General Automotive Discussion
05-04-2007 09:53 PM
MP1
04-20-2005 08:09 PM
Quick Reply: 2006 Navigator driver's door panel removal
