2015 6.2L Exhaust Help
Has anybody used the magnaflow kit#19174? I've been looking at the two avaiable kits frkm them but I'm not certain what the biggest difference between the side exit and the before the axle dump kit is. I assume the dump will be a louder kit and just how loud is the side exit kit. I dont want a realy loud system.
I think that may be a waste of time/$. The resonators are basically a straight-thru muffler with small baffles. You would be replacing one with another. I would eliminate the small one first and see if it adds enough sound for you.
My other suggestion would be to check out Raptor forums and see what has worked on their 6.2's.
Also, when the exhaust is pointing to the ground it blows up the dust or dirt under the truck. Then theres the potential of louder droning inside the cab.
Thanks man, you make a good point. I wasn't sure how much more restrictive the resonator was compared to a straight through muffler, I'm all about saving money ha. I should've gone ahead and had my muffler shop remove the small one initially, think I'll go ahead and do that. If it's still not enough I'll read up on what the Raptor guys have done, good advice
I removed the muffler on my current 6.2 and bent a piece of 3" to turn out at the tire. It sounded pretty good, just a little too much drone for me. My thought was the muffler does more than the resonators so next time I will keep a muffler and delete the resonators.
I just want a tad more V8 rumble with no drone.....
I have been wanting to try removing both resonators and the muffler, and replace all that with the quietest MagnaFlow muffler I can get. I also would try to exit the exhaust in front of the tire like some Raptors.
As I've mentioned in the past my truck has the large resonator and the cats removed. It was then custom tuned and I'm very happy with th sound. Not raspy like some cat deletes are and not to loud as I pull horses around a lot with it. I know many cant/don't like to remove cats but if you read about any of the more serious builds on a raptor.....you'll see the light, through your half plugged cat lol. Recall the recent thread in the 6.2 section where the guys entire bank of the motor wouldn't even fire because the cat had grenaded.
I'm happy with my exhaust the way it is, cheap and easy and far from a factory sound. Turns heads and spreads grins at WOT.
Factory muffler and small resonator still. No drone whatsoever or my wife would be whining. Extremely quiet in the cab. It's a little rank sounding for the first 30 seconds or so on a cold start but then quiets right down. I pull a three horse bumper pull loaded up around 8-9k two to three times a week. Generally when driving or towing alone I open the rear slider to be able to hear the exhaust note a bit better. With the wife/daughter on board I close it and it's quite quiet. At WOT from 4000rpm up it sounds awesome. Racetruck lol. My best bud has nicknamed it the fordrarri. Flamesuit on for the ricer comments. Lol. It don't bother me none. I know my truck sounds good by the amount of strangers its inspired to come up and ask me about it.
It also kicks a nice little bit of rumble on a warm start. Kinda just enough that anyone with an eye/ear for vehicles goes 'ok, now that's not stock'.
