[HELP] Pulling to one side and other when braking
I have a weird problem. My truck is intermittently pulling to either side when braking. Sometimes its the right, sometimes its the left, sometimes its hard, sometimes its soft.
Its a relatively new truck. 21K miles - 2014 F-250 Super Duty 6.7 Powerstroke.
I don't want to go to the dealer yet, because its emissions deleted, tuned, and lifted. I don't really want to hear their bull**** rhetoric.
I have unplugged the ABS sensors for a few minutes while running, plugged them back in and its gone away for a period of time, but now its back again.
Has anyone else run into this? Just trying to figure out what the problem is and see if its something I can just fix myself.
If worse comes to worse I will re-install all my emissions stuff to make a visit to Ford's festival of morons.
Both appear to be about the same from a look and feel. They don't appear to be overly shinny or glazed. I wonder if it would be worth while to just do a front brake job and see if that cures it. Re-surface the rotors and put some higher quality pads on it.
So here's some more info on this. Any help is appreciated.
I brought the truck to the dealer last week. First they never really duplicated the issue, because you do have to drive it for a while and heat things up to get anything noticeable. They just kept blaming the lift kit the whole time, I had to pick up the truck to use it for my memorial day trip this past weekend so I pulled it out of the dealer.
So while towing my 5th wheel up to the mountains this past weekend, on the way up it was driving me nuts. The harder I braked the harder it would pull to the right and I would have to compensate by steering left and it was only pulling to the right. After I got up to the campground I disconnected my ABS sensors while running, plugged them back in, and on the way home it was actually damn near perfect. I even had to stop short for some ******* and it did not pull at all.
So why would unplugging the sensors and simply plugging them back in make any difference? If there was a bad connection, it would throw warnings just like when I disconnect them I would think.
Any suggestions welcome! Thanks.
So that kind of makes sense, because I started having this issue after driving in deep snow this past winter along with the magnesium chloride they spread on the roads.
This is still a major problem, especially when I am towing.
I have replaced all the brakes, new slotted front rotors, cut the backs. It doesn't seem to matter whether the front ABS sensors are plugged in or not at this point. Still pulls to one side. I am very desperate at this point. The dealer is no help... they just want to blame the lift kit and bigger tires.
