Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
It’s time to put your foot down - Get All Terrain Landing Gear for Torklift GlowSteps
Old 05-12-2016, 02:49 PM
Torklift Sheryl's Avatar
Torklift Sheryl
Torklift Sheryl is offline
SPONSOR
Battle slanted campgrounds and uneven terrain with All Terrain Landing Gear
How often have you pulled into a camping spot found that it was perfectly level and solid throughout the entire site? The odds of that are probably close to hitting the lottery. Most likely the earth beneath your RV steps are uneven, whether from gravel, dirt, or grass, causing a hazard every time you go in or out of your recreational vehicle. Add this to the sensation of preparing for an Olympic diving attempt when you exit your RV or truck camper, you have the recipe for a nerve wrecking experience multiple times a day.
Avoid unstable booster steps
Torklift has revolutionized the way travel enthusiasts enter and exit their RV’s with the Torklift GlowStep product line. GlowSteps are a unique scissor step system which meets the ground when unfolded, offering a solution to the springy tendencies that comes with standard towable, RV and truck camper entry steps. With the GlowSteps and All Terrain Landing Gear, no longer deal with using extra RV booster step that are often unstable and a hassle to store. Whether you need two camper steps or six, the Torklift GlowStep line has the right fit for your camper or trailer.
The Original GlowSteps:
  • Glows in the dark for 10 hours with only five minutes of light exposure
  • Self illuminating steps - no batteries
  • Safely enter and exit your RV after dark
  • SureGrip™ step tread - no grip tape
  • Stores in position
  • Lockable
  • Exclusive: adjusts to basement model campers
  • 100% aircraft grade aluminum and stainless steel
  • Stainless bolted hinges allow for easy step addition or removal (Add-A-Step Kit Part # A7501)
  • Legendary Lifetime Warranty
  • Proudly made in the USA
(Above image: All Terrain Landing Gear)
Put your foot down on stability
Torklift has taken the GlowStep one step further with the creation of another accessory, adjustable stabilizing feet called the All Terrain Landing Gear. This addition creates a solid Earth to RV connection and adjusts to adapt to uneven terrain, leveling RV steps or leveling truck camper entry steps with the use of independently adjustable feet at the bottom of the steps.
This landing gear comes included as standard on the Torklift Glowstep Revolution step system for towables or can be added to any original Original GlowStep system giving truck camper entry steps the ability to adapt to any terrain, rough or smooth, level or not.
All Terrain Landing Gear:
  • All Terrain Landing Gear levels on uneven terrain
  • Can be retrofitted to fit all original GlowSteps and other step systems (GlowStep Revolution comes with All Terrain Landing Gear included)
  • Earth to RV: Level connection, securing the RV to the ground
  • Made from lightweight aircraft grade aluminum (rust free) and stainless steel fasteners, tested at 1,400 pounds per pair
Word on the street
On a popular online forum RV.net, someone purchased a truck camper that already was upgraded with the Torklift GlowSteps. Luck was on their side! Without knowing about Torklift’s GlowSteps, they inquired whether or not they should keep or replace the steps.
“[The previous owner] replaced the original steps with the Torklift GlowSteps as the original ones got in the way of the trailer he was towing.”
- Maxum1989
The response on the forum was unanimous- The Torklift Glowstep is a step above the rest, with multiple recommendations to also add the All Terrain Landing Gear.
“I have a set and I like them better than other steps that I have seen.”
- 69Avion
“Stick with the Glow Steps.”
- Kerry4951
“Upgrade the Glow steps with Torklift Landing Gear.”
- Wcjeep
All Terrain Landing Gear installs easily
See the full post and responses by clicking here.
Let’s recap, shall we? Torklift has changed the step game with the GlowStep line. Creating a safe way to enter or exit your RV day or night, with multiple options and add-ons to fit your needs. Installing RV steps is made easy and adjustment is painless. With unique bushing bearings and Picture2stainless steel bolted hinges for smooth function, Torklift steps provide ultimate level of quality and longevity. The Torklift All Terrain Landing Gear gives your steps the solid earth to RV connection on any surface. Stability and safety for your family is what it’s all about.
Don’t have the GlowSteps yet? The All Terrain Landing Gear comes as part of the GlowStep Revolution step system for towables. Enter our current RV Step Fail contest to win the GlowStep Revolution entry step system and check out the ways people have tried to solve RV step dilemmas on their own.
To add the All Terrain Landing Gear to your existing GlowStep truck camper steps, find a dealer near you.
Blog written by: Danielle Winski
To see more visit: Recent blog posts - Blog
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
08-19-2016 10:42 AM
Torklift Sheryl
06-07-2016 11:50 AM
Torklift Sheryl
03-22-2016 09:05 PM
Torklift Sheryl
05-29-2015 03:12 PM
Torklift Sheryl
05-19-2015 01:17 PM
Quick Reply: It’s time to put your foot down - Get All Terrain Landing Gear for Torklift GlowSteps
