Early First Oil Change on New Truck?
Wanted to get feedback if it is a good idea to change the oil the very first time in a new truck sooner to ensure no engine breakin contaminates get in the engine?
I have a new F250 6.2 that I have put 1300 miles on in the last month. First 1k break in, last 300 miles towing 8k. Was thinking of doing the first change at 1500 miles and then every 5000 miles after at that point.
even with today's modern engine machining .. dust/bits are still inside running around..
I think its a good idea. 40 dollars NOW could equal a lot of saving 10 years from now.
if you are like me... keeps things forever.. a real good idea.
past car 19 years and 250,000 miles . lawn tractor 25 years and counting.( still using)
I've been told that, at one time, an oil change was done as part of dealer prep on a new vehicle. And that no other "early" oil change was needed. Who knows if that is true or not.
2013, 6.2, 4WD. I did the first oil change when the computer told me to, around 7000 miles. Its up to 92,000 currently, & still gets changed when the computer says its time, usually 7,000 miles.
I changed mine early (1-3k) in all my vehicles, mainly it's a question of time spent sitting on the lot (which was MONTHS for my 6.0), compounded by sharing in this mindset:
Plus it get's the synthetic diet started early, not sure what factory fill is on the new stuff but I know for sure what's been in mine since 1k miles on the odometer.
Plus to anyone who's going to argue that changing the oil early is simply wasted money poured down the drain, I expect that to be accompanied by an explanation of how you max out every rating on your Super Duty and in no way are wasting money on a Super Duty when a less expensive lower rated truck would work. I'm not going to nitpick on one certain cost segment of ownership like oil changes, nor get my underoo's in a twist over one $100 oil change when it was new when I've burned about 8,000 gallons of diesel at an average of $3.50/gal for an eye-popping $28,000 in fuel cost since then.
Plus...how long did the truck set on the lot...or was driven in short intervals before you bought it?
