Hub assembly
The best bang for the buck is the Timken assembly. Weather you have ABS or not, get the ABS hub. Just cut off the wire if you don't need it. Do both wheels at the same time, it'll save you a headache later.
As for the half shaft, are you sure you need it? If so, you can get both the Timken hub and the motorcraft shaft at Rock auto.
When I bought hubs for my truck, I noticed that 3of the 5 Timken assemblies I looked at had been pressed together at the factory improperly. You can twist the assembly with your hands to feel approximately how hard it is to turn. Look at the stub needle bearings for being crushed at the factory. I found both those conditions.
Doing my 03 hubs right now, went with Moog because of the seal.
Also might want to replace the esof seal and outer axle tube seal while you are in there.
Additionally check the ujoints and replace them as well.. Believe me you don't want to take it apart again.
rockauto had the moogs for 150 each, deisel oring supplied the seals and orings. Moogs also cam with studs.
Sucky job.
Sucky job.
The first thing that I did was twist the hub with my hands to feel the torque needed to turn the bearing. It should resist turning, but there should not be any "shuddering" which would indicate too much hydraulic force applied by the automatic press in the factory.
The other problem with the stub shaft needle bearings was obvious from looking at the bearings. You should be able to push the bearings with your finger around the race. I found one hub that the factory had crushed the needle bearings by applying too much force during assembly. The needles were laying over at an angle from being crushed.
The equipment used at the factory is automatic, but does require periodic calibration.
Larry
I took my first bad hub apart and found the races were machined into the hub. The roller bearings were simply pre-loaded with the large nut/threads torqued to some spec. I have some pics in one of my photo albums. The damage to the needle bearings sounds weird - why would a press fit use the needle bearings for that process. It almost sounds like the after market guys use a different procedure for assembling these hubs or they are fabricated differently from the one OEM unit I took apart. Just curious regarding some of these observations.
How do you know that the Timken unit bearing you installed wasn't made in China?
Timken currently operates over 26 corporate facilities in China, including 2 distribution centers and 6 manufacturing plants.
I noticed that the cardboard box the Timken unit bearings for Ford Super Duties are shipped in says "Printed in the USA".
Who are these companies fooling? "Designed in the USA." "Packaged in the USA." "Printed in the USA." Oh great, it says USA on it. Must be good.
Timken has operations and markets all over the world, but I would not be so quick to assume that any given part from Timken that is sold in the USA is actually made in the USA. With these unit bearings in particular, it could be Mexico or China... where many other OEM parts are made that eventually find their way into vehicles whose "final assembly" is in the USA.
