Sponsored by: DashLynx
fuel issue with my 94 f350 IDI turbo diesel
Old 04-27-2016, 05:46 PM
dasbro's Avatar
dasbro
dasbro is offline
Question fuel issue with my 94 f350 IDI turbo diesel
hello need advice, my obs idi just shut down on me and i did the process of elimination and i thought i had it narrowed down to the lift pump, so i replaced the pump and i am not getting any fuel to the pump from either tanks, is it possible that i have bad sending units in both tanks that went bad at the same time?? i think its odd that nither tank will produce fuel. Can i use compressed air to blow out lines from the lift pump line to the tanks or will this cause dammage to the slector switch for the duel tanks. all advice will be greatly appreciated
Old 05-05-2016, 05:31 AM
redford's Avatar
redford
redford is online now
Received 1,594 Likes on 932 Posts
Try posting your question here, in the Pre-Power Stroke Diesel (7.3L IDI & 6.9L) engine forum. You should get some answers.
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
Old 05-05-2016, 05:40 PM
dasbro's Avatar
dasbro
dasbro is offline
Thank u REDFORD!!
wdbauch
New Member Introductions
05-31-2008 01:28 PM
aldridgel
12-08-2004 01:50 PM
Quick Reply: fuel issue with my 94 f350 IDI turbo diesel
