Quote for installing 4.30 gears
With the smallest tire option and going to 37s and 4.30s will be right back at stock. You can put a regular Dana 60 gearset in a super 60. The 2011-up 10.5 is a 37 spline pinion and current the deepest gear is a 4.30. With the correct bearing and companion flage it would be possible to use and older style 31 spline gear set.
They can be pretty tight but nothing a little work with a bar can't handle. This one was rather interesting being the carrier fell out. Has 8k on it. There was .015 lateral in the setup on the carrier, the slinger under the inner race was all beat up and the slinger under the yoke was missing. Must have been built on a Friday.
They gears about even up on the bigger tires. It will put you about stock feel. Would have like to go 4.56 but it was too much hassle or parts and conversion to make the older 10.25 gears work.
With 37's on the V10 trucks guys usually went with 4.88 gears. Keep in mind the V10 made more torque and at lower rpms than the 6.2l.
There's now way. Newer gears and axles are the best they have ever been with tolerances but not to reuse all the shims. Not saying it can't happen. I will say most pinion depths have been within a thousandth, 2thou at most from the factory shim. Backlash from the factory is set with surface ground shims. I have never seen a diff that was that close to reuse those. Bad advice from nitro for sure.
#28
Marking compound. FYI, get another inner pinion bearing. Unless you bought the new clamshell to use in a puller it will probably kill the bearing. It's a dealer only bearing. Order a super carrier shim kit for a Ford 10.5. The dealer is the best value for gears. The front is pretty much a complete kit minus carrier bearings which need pulled since the shims are under the bearings. I can't remember if the rear comes with any bearings or not.
#29
#30
Would depend what nitro meant. Should be no reason you can't re-use the shims but it will have to be adjusted to fit new gears. Not a good chance the original shims will be the same dimension you need for the new gears. May have to add or remove from the original shims but they are not junk.
