Need Stake Bed advice for '49 F1
I'm looking for either a stake bed kit to purhase for my '49 F1 pickup. If none is available, I will have to do the full Monte and purchase the wood to make my own. I don't really want to do this because I don't have the wood-working tools or garage space that would make the chore fairly easy. I'll go this route only if I have to.
Any advice as to where to look for a filnished stake bed kit that includes the wood, the bolts, etc.? This is not the kit to replace the wood bed floor; it is the kit that is anchored in the vertical stake bed pockets (there are four in the '49 bed). I tried looking in the Mac's, LMC, and Classic Haulers catalogs. May have missed seeing what I want there, but my eyes are not what they used to be.
Thanks,
Smitty
Thanks,
Smitty
From Mac's:
Ford - Ford Pickup Truck Short Bed Side Board Set - Unfinished Oak - Macs Auto Parts
Like this?
Like this?
From Mac's:
Like this?
Like this?
Last edited by Smitty550; 04-12-2016 at 10:12 AM. Reason: Tried to delete, but don't see any way to do it.
The truck is just an F1 1/2 ton (not a flat-bed), simillar to the one in this picture. I was thinking of a design more like this:
http://static.howstuffworks.com/gif/...-pickups-2.jpg
Have this f-1 collection
was wondering if the 51 f-1 came with stake bed running boards? I know the 48-50 did come with the running boards.this is why im adding to this section of the forum...I know that red truck has wrong boards, as far as I know. I have a 51cab/Frames and I have 48 script bed with proper running boards...also dose the vin numbers reflect a stake bed--- I don't think so, am I wrong? Here are some pics
Don't forget to use high quality stainless steel nuts and bolts. I did these for a friend on his '49 Dodge pickup.
https://www.ford-trucks.com/forums/1...y-flatbed.html
OK, 1948 only I'll have to look at the vin on my others, but they are f-2s and need frame cut, don't know if I'm into that...well now I know. As for the stakes bottoming out or if they have a floor, I will have to check that out good question.
I did notice when I was taking out the bench seat out of what I callef a 51( I haven't looked into serial numbers yet to see real year) then to keep the bolts original I put them into the one I'm building up; the one I took out seat had 4 bolts in front to hold the seat in, and the standard 2 in the back...where as the other 51? Had only 3----two under driver, and one under passenger p? Weird...also the bench seats seemingly original first fabric was old Army canvas? In addition it had what looked like one side of a hindges on both sides of the neck area riveted on rather well, but not stock? Military add on? Weirdness the truck was in bad shape as they drag it around the yard by its windows, maybe with a forklift...it also looked air force blue, but no data plates anywhere. Just like a 51f-3 ihave/ the blue paint that is.
If the stakes don't bottom out then something has to sit on the bed rails. I would think that if that were done then they would vibrate and wear the paint off.
