Driver barn door wont open
Had my excursion for a couple months...and so far I have not been able to get the rear door open on the driver side.
I was able to remove the plastic panel so I could see inside.
The cable is attached to the handle, but not the latch mechanism at the bottom of the door.
I have searched this and other sites and looked for pics on the internet...no luck yet.
If anyone has an image of the latch mechanism for the driver barn door ... something that will hopefully show where the cable attaches and/or how I can manually (no cable attached) open the door.
Also, I am having issues with the door ajar light.
I am almost certain that this is from the rear of the truck.
Is the sensor for door ajar on the hatch, driver barn door, passenger barn door, more than one?
Thanks,
Anthony
Thanks,
Anthony
Thanks,
Anthony
Thanks,
Anthony
Any chance you can explain how you operate the latch by hand? I hate to show everyone how simple I am...but I cannot figure it out?
I have pulled and pushed every part of the latch mechanism I can and have had no luck.
Pic would be perfect if anyone has one as I am not sure the latch mechanism isn't broken...at least I keep telling myself it must be broken since I cant figure it out.
Anthony
Thanks for the reply. I can at least start looking at the hatch for the door open sensor.
Anthony
Anthony
I REPEAT: There might be an easy fix with replacing the cable I do not know what is wrong with yours, BUT It is fairly common issue. I needed to open my door sooner rather than latter
1/8" drill bit. Drill out the rivets on the handle. Remove handle & cable. Toss them in the old parts pile I'll never use again pile. When I want to open the door I stick my hand inside the hole & push the latch.
I have tried to push and pull and haven't been able to.
It is an obvious lever?
This is a pic of what I see inside mine...cant tell if it has been apart / butchered by PO or not.
Thanks,
Anthony
This may help you out- it's in the tech sticky section.
https://www.ford-trucks.com/forums/1...l#post15894412
Bottom right..It is a little lever you push down. You can not see it with your hand inside BUT look at it then just kind of feel around while pushing down on things
Anthony
Either I'm a lot less of a man than I thought, or there is something wrong with the doorlatch. I'm getting really close to trying to cut the latch out, but I'm nervous about damaging the door in the process.
Thanks again,
Anthony
