no, I thought about doing that, but I plan on going darker with the red, so far I'm set on this color: http://www.houseofkolor.com/kolors/detail/index.html?id=HOK000103-01&ref=kolors
But I've got a ways to go before I get around to repainting.
Hey guys, been a little while, I've been getting parts together for my front suspension system, mainly scrap steel for welding mounts to the I beam and frame for coilovers. Pretty soon I'll be digging in and will post pictures as I get this set up. Thanks guys
Can't wait to see. I just redid mine, and I'm about 5/7 drop. Doing drivetrain and body swap next week
Damn. And I thought I was low. I want to see what that looks like with everything on it! Exhaust wise I think what you were talking about is the best solution I can think of, unless your going to run short side pipes
Finished up prep work tonight for welding, marked where lower coilovers mounts are going to be, once they are mounted I'll be welding a flat piece of steel to cover up the hole in the shock tower for the upper mount, then I just need to find a way to line up the upper mounts to the lower mounts.
Ive been told to play around with the spring rates to get the right one since I don't have the equipment to do four corner weighing. But I'm planning on going with varishock double adjustable coilovers from Chris alston's chassis works. I'll be ordering a 4 link kit through them as well that uses the same coilovers.
Thanks festus, I think I'll find someone, just picked up a welder yesterday, gonna do some practice and then get everything welded in so I can measure and order my coilovers!
Heres more of mine. Not totally settled in yet, and i still need to add more parys, so it will sit lower.
