NIIIIIIIIIIIIIIIIIIICE Brownw,For using a FORD 5.0 COYOTE in a FORD instead of less colorful adjectives Chevy LS engine,Like anybody would've,Heck if your 85 F150 was mine I'd use a 5.8L GT500 engine besides the 5.0 COYOTE
Reason: add emojs
Brownw,Paul Horton Welder Series 60" Width Mustang-II I.F.S.,Is the only thing I can think of ,Also Brownw when u talked about installing a LS in your 1985 f150 hot rod project,U should've put LS Differential
Reason: typing
How y'all doing? Finally got around to test driving the new brake system, works well, not much improvement over stock but I haven't found a brake booster that will swap with mine designed for four piston calipers. Anybody got a car that the brake booster will swap right over on?Also noticed my passenger side rear wheel is shaking fairly violently, gonna have to tear that apart and figure that out before any other test drives.
Brownw,Are planning to repaint your 1985 f150 hot rod project the factory red paint,Because I'd like the factory 2-Tone on the 1980-'86 F100/F150 Pickups,My 2-Tone would be FORD Laser Red & Oxford White paint scheme BroncoDually
