Custom Roof Rack
Somewhere on YouTube I came across some locking tool / junk boxes that had a base you would bolt onto your rack. Then, the boxes would snap (and lock) into the base. I've looked for something like this online with no luck. Anyone seen such a contraption ? They were obviously a mass produced item, not custom built.
So today i went buy the shop that says they can build the roof rack. It is just a little husband and wife place. The guy was building an exo skeleton for a suzuki samari...
We talked about the project a little and about Excursions A LOT.
If I can get the money lined up, I should be having him start the project late next week. At that time, we will finalize everything.
On a side note, should I look at having him fab up a side mounted ladder? If I were to do this, I would have twin ones made, one for each side.
Personally, I like the side mounted ladders. My only issue with them is that around these parts, you wouldn't need to be much off the beaten path to have a tree turn it into a pretzel. I would only want one, not two though. I think I would want mine to be relatively easily removed if the need arose though.
Interesting points about the ladder option, maybe something like this would be better.
Rhino Rack Folding Ladder - Rhino Roof Rack Folding Access Ladder
I just wonder if a built permanent one would be cheaper since I already have him building the rack...
on
It is also a great to place to relax and enjoy the view.
#29
[QUOTE=Twitchyleprechaun;16167290]I have had my rack for about a year now with no ladder. I have not had an issue with accessing it. Open the door and stand on the running board or the inside of truck or use the tires to stand on. I have thrown many things up there. There has been a few times where I did need to jump and pull myself up so I could stand on the rack to move things around and load and unload.
As you age Twitch, you will find that jumping on & off a 7' roof rack is not in the cards any longer. The stock rear bumper is useless & the door jamb is not a very secure platform either, You (I) have to keep one hand on the rack at all times so as not to head backward.
#30
on
