1989 F150 XLT Lariat
#32
#33
Milling a mile off the e7s, requiring the use of 93, will net a noticeable power bump combined with a nice and "crispy" throttle pedal. The gt40s will net an additional substantial increase, but if you can't find a set for cheap then you can settle for e7. Don't get me wrong, gt40s are much better than e7, but if you can accept the fact that your 302 will be a turd regardless of what heads you bolt on top, it might allow you to sleep better at night after choosing the dark e7 path.
#34
I have yet to find gt40s's I've seen a bunch of gt40p's, but the people want $250 for them and they still need worked. While I'm not opposed to better heads I need to keep my budget at $800.
basic rebuild kit is $330. That leaves $470 for everything else.
Everything else =
- check and deck heads
- or new heads
- timing chain ($40)
- Cam set with lifters
- headers
- mufflers (getting rid of the glasspacks)
My thoughts are to do all the engine internals now ie. the timing chain and cam then upgrade the heads and add headers later. Those are relatively easy bolt-ons. Compared to adding a cam in 6 months.
Then if the rest of the truck doesn't fall apart I'll work on upgrades.
That's just my thinking. However If I did come across a set of GT40S heads for the right price I'll jump.
Also what hone is recommended? I was going to go with a 4" 240 grit ball hone.
#40
#41
Just my luck.
Could I just get this? Put my intake on and rock it?
302 for sale
Am a hoping for too much? How much did the block's change?
302 for sale
#44
#45
It seems to have good bones. I have a 1989 F-250 XLT (manual locks and windows, tilt steering, A/C, etc.) that needed a new engine, among a list of other things. I bought a junk truck with 60k on a Jasper rebuild for $350, swapped the 302 and installed a rebuilt Mazda 5spd. Counting purchase price, I'm still under $2500, which is $1000 under my stopping point. She's finally running, sitting, and driving right...like new.
I'd see if you can locate a running engine to swap out before considering a rebuild. It may save you some bucks in the long run.
