Air bag DIY Replacment
Old 02-01-2016, 04:37 PM
2Sachse's Avatar
2Sachse
2Sachse is offline
No weight sensor and you can't tell it's blown by looking...
I don't think there is a weight sensor in the seat for 2002. I've not seen it AND the passenger side deployed while the seat was empty. So I'm reasonably sure it doesn't exist on this model year.
Just another bit of FYI if you find yourself in this situation, that driver's side pretensioner in the pic that looks ok? It's blown. Throws a code 46. So evidently you can't tell if a pretensioner is good or not just by looking at it.
Last edited by 2Sachse; 02-01-2016 at 04:40 PM. Reason: Added a pic of the blown pretensioner that 'looks' ok. It's not.
Old 01-09-2021, 02:07 PM
Larryaka90's Avatar
Larryaka90
Larryaka90 is offline
Airbag impact censors
Originally Posted by 007ROADSTER
Each airbag cost $250 (salavaged). After I replaced them (it was a snap) I still had an airbag light on all the time. The airbag computer had logged the blown bag fault. I talked to a mechanic friend of mine, and he said it would be about $100 to have the fault cleared by a dealer. I bought a replacement air-bag computer ($60, salavaged) to fix this.
The whole thing was pretty easy. Just make sure you're careful handling the airbags (so you don't accidently set them off) and disconnect the battery several hours before you work on your truck.
I have to tell you though, I was a little scared turning on the ignition on the 1st time after you replace the bags.
I got the bags at http://www.fivestarairbags.com/ but I'm sure there are plenty of other places to get them.
did you have to change the impact censors in the front of the vehicle?
mustang2270
1997 - 2003 F150
03-16-2009 08:34 AM
deereman4020
02-16-2009 08:10 PM
serialbowl00
05-05-2003 09:31 AM
pc36
1997 - 2003 F150
03-21-2003 12:20 AM
Frank_SJ
01-05-2003 08:26 PM
Quick Reply: Air bag DIY Replacment
