1988 F350 7.3 IDI
1988 F350 7.3 IDI
Year: 1988
Make: Ford
Model: F-350
Price: $3000
Mileage: 129000
Color: Gray
Private or Dealer Listing: Private Listing
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
Color: Gray
Engine: 7.3 IDI
7.3 IDI
5 speed ZF transmission
10.25 Sterling differential 4:1
Some body rust, needs paint. 129,000 original miles.
100 miles on transmission and differential fluid change, new carrier bearing and u joints
Brakes new from master cylinder to rear wheels
Lots of extra parts included, see below.
Runs and drives. $3,000.00
Used Parts
1-grille
1-radiator
1-radiator shroud
1-timing cover and gear
1- headlight
2-tail lights
1-intake manifold
2-cylinder heads
2-exhaust manifolds
1-water pump
1-vacuum pump
1-fuel pump
1-radiator fan
1-radiator fan clutch
1-a/c compressor
1-a/c condensor
1-fuel tank sending unit
3-injector lines
7-injectors
1-differential cover
various pulleys, brackets, etc
NEW
3-wheel seals
2-axle flange gaskets
1-axle o-ring
1-fuel pump with gaskets
1-ignition lock cylinder
1-complete fuel return kit
8-glow plugs
fuel filter
oil filter
side marker lights
http://i446.photobucket.com/albums/q...pszkojl3yn.jpg
http://i446.photobucket.com/albums/q...psybcqhtha.jpg
http://i446.photobucket.com/albums/q...pslll7snpy.jpg
I have more pics, just want to keep it dial-up friendly.
chibravo
06-02-2016 08:51 AM
KTMcrazy
16
12-03-2012 04:30 AM
DarrinGT
Ford Truck Parts for Sale
19
05-31-2012 09:08 AM
