Random Smoke, need help diagnosing please
Lately my truck has been smoking at random, it's not very often & only seems to happen while stopped with transmission still in gear (traffic light, etc)
& at this time, I believe its a faulty fuel injector (still originals) although not confirmed.
Hopefully it can be diagnosed without taking her to a garage, as $ is tight
2006 w/a 6.0 Diesel (130,000 miles) no CEL
Thanks
Thanks
In fact after you've driven it 10-15 minutes & come to a halt, is when the smoke happens.
Oh & if u jump the throttle while its smoking, it will almost immediately clear up.
After I shot that Video today, I shut the engine off a few minutes & the rest of the day she ran perfectly.
FICM was rebuilt by ED 3-4 years ago & still puts out 48-49 Volt's constantly
Yes, still has a functioning EGR.
https://www.ford-trucks.com/forums/1...l#post16101870
In fact I pulled it yesterday to look for Coolant, please see my Post, from another Thread ^^^
Yea valve looks good and oily soot is normal, I would think if Injector seal are blow by you would be seeing blue/ black smoke , there's been weirder things happen though , back to FICM testing stone cold yea? Maybe the Banks playing games any way to put it back to stock.
Is there some other thing I should be doing to check FICM (I know of Sync, but hell if that's off it don't start)??
My Programmer is a Edge CTS & yes I could, OR are u talking about the Banks High-Ram Intake??
If your talking about the High-Ram, I do have the OE Intake Elbow, although I don't have the OE plastic CAC Tube & the Banks steel CAC Tube is much larger.
Thanks for the tip, I don't know why but in my mind, I am thinking Injector too
I called a local shop "PowerStroke Gearheads" & described to him my issue, he feels its the Turbo. Any thoughts on that?
Anyway I am taking it over there in about 30 minutes, so I'll post his thoughts later....
Thanks guys
Thanks guys
Well the shop said.....Turbo
So I suppose I start learning about options for the Turbo, after some brief reading & consulting with the shop, I am liking the PowerMax (Stage 1) since I still have OE Injectors.... Although when the time comes, I have felt the 155/30(probably Warren) is a great upgrade for a mildly hoped up engine.
How many currently run a Stage 1 PowerMax & thoughts/experiences w/em
Me too....
It started smoking when I pulled in & the 2 guys there immediately said Turbo, especially if it goes away after accelerating. The way he explained it, the oil is getting through the turbo when the turbine is spinning more slowly & the bearing shaft can shift back/forth.
I stated I was worried about Injectors, he said if an Injector tip was broken, it would smoke constantly & he proceeded to explain how the engine would sound while starting if an Injector was leaking back (dangers to hydro lock) and that it would be evident.
I will say this (which I didn't tell him) for the last maybe 2 years, after shutting engine off, you can hear the Turbo spooling down (whooch, whooch) & I've told the wife numerous times I feel the bearing was going bad in the Turbo.
I assume VGT is functioning only because, % seems to change with Turbo load, although I don't really know what it should read.
I would feel better buying new on this, due to noises its made for awhile (afraid of cast damage) plus I like the idea of a better performing & sounding Turbo
