Need help with 89 f250
Hi im new here, i've had some issues lately with my truck. It is a 1989 f250 with a replacement 302 and automatic trans with about 75,000 miles. Lately its been having an issue where when im stopped at a light its idle will start loping to the point where it almost dies and i have to tap the gas to keep it going, along with that at mid range rpms (1800-2300) it seems sluggish and the engine again revs up and down. if i stomp on the gas during this it might hesitate for a second but will jump to high rpms just fine. Typically It does not do any of this till the truck is hot. So far i've tested my tps sensor, gone through and checked my fuel system, and replaced my iac with no results. Im thinking its possibly the icm on the distributor or my ignition coil?? Any help would be great thanks!
I agree, but would check the fuel pressure reg before I started jacking with the ecu. Also might want to try plugging all the vacuum lines except MAP and FPR and see what it does. If it has the metal vacuum coffee cans they rust on the side seam under the bracket.
enrgizerbunny
11-17-2014 07:31 PM
daddygreenjeans13
28
04-05-2013 08:58 PM
