Having True Trac installed in 2003 4x4 Ex
Old 02-24-2016, 06:52 PM
wallz's Avatar
wallz
wallz is offline
When I had mine done I ended up having them replace all the bearings as well while in there.
Ended up with the alum 08 cover.
A little to get used to in the snow, especially if going up a hill and auto shifts down a gear you usually end up going a little sideways. You learn to deal with it and it is then fun.
Freeked the wife out the first time that happened to her and I wasn't there with her.
She now drives the Expy.
  #32
Old 02-24-2016, 08:09 PM
freesoul's Avatar
freesoul
freesoul is offline
what was your cost?
  #33
Old 02-24-2016, 09:39 PM
henryr's Avatar
henryr
henryr is offline
Originally Posted by Skip1970
Get a Detroit or arb
which ones ?
  #34
Old 02-24-2016, 09:46 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by henryr
which ones ?
Do it. Do it. Do it.
  #35
Old 02-24-2016, 09:54 PM
henryr's Avatar
henryr
henryr is offline
the ARBs are all air locking... that a bit overkill for me..
  #36
Old 02-24-2016, 10:02 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Price aside, they are actually ideal for those that only need a locker occasionally .they work the same as a open diff until you hit the switch and then they lock.
  #37
Old 02-24-2016, 10:11 PM
pirate4x4_camo
ARB operates the same as an open diff until you activate it with a in can switch and then it works like a spool by solidly locking both axles together.
Detroit will allow the outside wheel to spin faster then the inside wheel in a turn but neither axle can turn slower then the ring gear.
ARB cons are it is expensive, pros are it is very reliable and predictable traction only when you want it.
Detroit cons are the can cause some quirky handling and are always on. , pros are traction and cost
  #38
Old 02-25-2016, 12:39 AM
wallz's Avatar
wallz
wallz is offline
Originally Posted by freesoul
what was your cost?
Up in Northern Canada we get hosed on everything.
Paid about 900 for the true trac, delivered, about 250 for the bearings from ford and I dont recall what I paid the mechanic to install it. Probably 300.
  #39
Old 02-25-2016, 07:54 AM
henryr's Avatar
henryr
henryr is offline
anyone have experience with 4wheelparts installing stuff ?
  #40
Old 02-25-2016, 10:52 AM
freesoul's Avatar
freesoul
freesoul is offline
Smile
Update: just spoke with original shop and I am going with them for 2100 out the door. While I may have been able to save 300 (200 if it didn't include tax) this shop is highly recommended and I want it done right the first time. They are getting me for about $100 on what I can buy the unit for myself, he went through the breakdown and everything else is in line incl the $80 hr labor. Will include everything except the hub bearings which will be another $70 if they can't be reused. I am going to get the 2008 cover.
I appreciate all the replies, I will post a followup after its done in 2 weeks.
  #41
Old 02-25-2016, 12:14 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
It's only money son. Get it done and forget it
  #42
Old 02-25-2016, 12:21 PM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
For him- It's only money.
For the shop- It's hookers and blow time, baby!
  #43
Old 02-25-2016, 12:22 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Hey them snap on tools g-strings and snow white don't pay for themselves right?
  #44
Old 02-25-2016, 12:43 PM
holeshotwalt
Amen, brother.
  #45
Old 02-25-2016, 12:50 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
When u pick it up look for white residue under the guys nose.
Quick Reply: Having True Trac installed in 2003 4x4 Ex
