2008 sport trac sway bar links
can anyone tell me how much you should tighten the sway links on the front of a 2008 sport trac. I am using OEM links I have been told that with aftermarket links they should be tightened until bushings compress to same diameter as the washers. however with the OEM links this doesn't seem right.
