clutch kit recommendations 86 f350
The 6.9 clutches are even less. Go to RockAuto, look up 1986 F350 6.9 diesel manual transmission parts. The LuK rep set 12" upgrade Luk07065 is $96.79. Then look up flywheels, the LuK LFW386 is $134.99. Total 231.78 plus shipping. But you will need the 6.9 bellhousing. As tjc mentioned, the 4 speed is pretty horrible for highway use. Without overdrive the poor diesel really screams especially if you have low axle gears. Mine has 4.10's and the previous owner added a gear vendor overdrive to make a 3.20 final drive ratio. 75 mph is do-able but I'm still reaching for another gear... So I'm getting a ZF plus the GVOD to off set the 4.10's. An overdrive transmission and 3.55's is another good highway combination. Just something to consider. The IDI's rev out at a lot lower rpm than a gasser so you won't be going anywhere fast with a T19.
I just ordered the clutch and flywheel from rock auto that you recommended! Now i need to get brake lines and fuel lines! hopefully I will have the old thing moving under its own power this spring!! Thanks for the helping finding the clutch that I needed!
Oh man!! I have a centerpiece DF from the 460 that came out of the truck that has minimal wear and grabbed like a bear!!! Oh well I'll just hold on to it for a future project. Thanks though! All new stuff in there now.
RenoHuskerDu
12-08-2017 06:44 PM
Bob Shumway
15
12-03-2014 04:08 PM
southtexasidi
13
07-08-2012 03:02 PM
Chris Cook
02-16-2003 10:29 PM
