Late 50 F1 steering box and tree rebuild
#31
#32
#33
#34
#36
#37
I could never get worm and roller mesh up the right preload and could feel the sector bushing play in the pitman arm. So I decided to do a more thorough rebuild. Pressed the sector bushings out of the housing. Split the worm gear with a cut and then chisel. Froze the shaft all day and then heated the new worm in the oven for a little while. I went on nicely with a few whacks on a piece of oak. Waiting on new sector bushings.
#38
Pressed new sector bushings in tonight, honed lightly with brake hone to even out slit, then reamed to sector size, about 1.125ish. Sector slides in like butter with no play or wiggle at all. I think I had several 000's play in the bushings I had.
Used the harbor freight adjustable readers, fine from my point of view.
Will go further tomorrow on setup.
Jonathan
Jonathan
#39
Dear sir,
I wanted to give you a note of appreciation for your steering rebuild post.
I also have a question, in one of your first pictures you have your parts laid out on the bench and your drain plug looks similar to mine, it says HEAVY GEAR OIL on the end and there is a small hole in the center with a small cotter pin installed and slightly spread open inside the plug. Is yours like this, and if so, does it leak from that location?
I am probably going to use the 900W oil as the book says (I am in Michigan and it gets too cold here for just grease)
Thanks for your time,
Doc (Michael)
Doc (Michael)
#41
#42
#43
#44
Bad enough and I have made it a habit to change races with bearings ( and I am a cheap guy!) It had some significant wear patterns. It did not have the fine cracks and obvious heat issues as the bottom race.
I made my tool to remove the race out of a 10" long piece of 1/4" square stock.
It worked a breeze!
Doc
PS waiting for parts is a drag!
It worked a breeze!
Doc
#45
Help!
Help!
Big question! My parts arrived today and I was so excited to install the parts. All of the parts are too small!
I did not have an old column/gearbox and bought this one of eBay. Is it possible that I have a gearbox column out of a larger model truck and everything is just larger?
Thanks,
Doc
Thanks,
Doc
