Because Race Truck
#31
I sure hope so. Tonight I'll start welding on the firewall. Hopefully get the patch panels finished up tonight or tomorrow and start trying to stuff an engine back in it later this week. Before I drop the engine back in there, I aim to take a little bit of weight out of that crossmember. I am hoping to cut a hundred pounds or more out of the truck not including removing the A/C system. The main areas I'm looking to remove weight are the crossmember under the engine, inner fenders, fender wells, core support, rear crossmember, inner doors behind door panels, A/C system, cab, seats, bed, and rear bumper.
Personally, I would be worried about weakening the engine crossmember with the kind of power you are hoping to make, but I am sure you could build something out of DOM tubing that would take the abuse and weigh a heckuva lot less than that stamped steel monstrosity that is in there now. Is the driveshaft from the 10.5 up to the task? Aluminum? Remember you will make up some weight with the lexan rear window too (not a lot, but some). You know what you're doing, I'm sure you'll do it up right.
#33
#34
That shouldn't be too hard to do with the things you have listed. I would bet you make up half that with just the rear bumper delete. I don't know what a rear roll pan weighs, but it can't be much.
You and me both buddy. I haven't taken that truck down the track in a little over 3 years now, so I'm definitely itching and I'm starting to be afraid to break the SD. I must be getting old.
It will roll all of the coal. Hopefully it won't be too bad though. We'll be detuning it quite a bit to try to help the connecting rods survive until I can put together a built motor. I'll push it, but I won't push it all the way until it has billet rods. I probably will only plumb one of the nitrous solenoids.
#37
I got some work done on it this weekend. The firewall is finished and I have started putting the truck on a diet. I need to take some more stuff off the truck to gain access to the whole inner fender so I can take weight out of those. Once I'm done taking weight from the inner fenders I'll work on getting an engine back in there.
#40
#42
#43
Hi Bill!! I been good man. Mostly just catching up on maintenance on my little diesel car. But speaking of sick trucks, it looks like I need to catch up on Big Red's build thread. That thing is mean!!
Shoot me a text when you do if you still have my #. I'd like to see that go down.
#44
I still have your number. I'll holler if/when I'm up there for sure.
#45
Didn't get a whole lot done tonight. Cleaned up the lightening holes I put in the frame and cross member and painted the rest of the front half of the frame... next I'll be taking the insulation junk off the top of the fender wells because its all torn up. Then I'll start prepping the new engine to go in.
