Looking at F350s with 460, any year better? Other things to consider?
#31
Trailer with 5500lb axles = 2500lbs
Random stuff= 500lbs
Total =~10000lbs
Still, even if i'm over I figured a 350 would be fine. I wont go anywhere quick, but should do the job fine.
Am I overestimating a 350's capabilities? I talked to a ton of guys that said i'd be fine even with a newer F150...I've towed ~15k with my '93 F150 back in the day a few times, but I wouldnt do it often.
#32
#33
#34
This guy wants too much
96' Ford F250 XLT quad Cab,4 Door,Seats 6,HD 1 ton rear end F350
1997 Ford F350 XLT crewcab long bed single owner!
Easiest to find in SRW.
#36
Clean low mileage but not quite what you're after
1996 Ford F-250 Super Cab
And there's a bunch of crew cabs out there. Hard to find a nice F350 single cab
#37
This is different. 4x4 F350 with 12' Stakebed
1996 Ford F350 4x4 4WD 12' Flatbed Stakebed Truck Pickup Dually Gas -
#38
#39
I figured race weight = 7000lbs
Total =~10000lbs
Total =~10000lbs
1. they dont make 5500lb axles
2. a 10k trailer (5k axles) weighs about 4,000lbs
3. That leave you about 7,000lb weight capacity with 1,000lbs tonge weight on the tow vehicle
A f350 460 4.10 truck would do just fine towing a 7,000b truck on a 10k trailer
#40
#41
My 14k deck over trailer was advertised as 3500lbs. it was more like 5200lbs
They all lie and say they are lighter than they areThen in the small print that say weighs may vary
#43
And for the OP
Guy CLAIMS it has rust free fenders but you can CLEARLY see the ROTTEN drivers fender
https://allentown.craigslist.org/cto/5413301301.html
#44
#45
You better do more research.
You answered my root question with your final statement though, thanks.
