Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
8 lug Ford rims...
Old 01-24-2016, 06:10 AM
MikeL67's Avatar
MikeL67
MikeL67 is offline
8 lug Ford rims...
Question...
Will the rims off of a 1988 F-250, a 2000 E-250 and a 1977 E-250 all interchange?
I have a 1077 Van that I want to get new chrome rims for, but the rims are from a 88 F-250. I currently have rims off of a 2000 E-250 that I'm hoping will fit the 77 also.
Any info on this is greatly appreciated! Thanks!
Old 01-24-2016, 12:44 PM
fordman75's Avatar
fordman75
fordman75 is offline
They should all interchange as long as the center holes on the rims fit over the hubs. The bolt patterns are all the same.
There is a difference in the tire size. I believe the stock 77's were still 16.5" ( I know you said you aren't running these ) , the 88's are 16" and I'm not sure if the 2000's are still 16 or if they are a larger size. If you are planning to use your existing tires. Make sure to double check the size of the rims you plan to buy.
Old 01-24-2016, 04:25 PM
MikeL67's Avatar
MikeL67
MikeL67 is offline
Thanks.
I have 16" on my 77 now. I want to change out the rims to new chrome and black. The only way I can order them is to say they're going on a 1988 F-250. I plan to put a smaller tire on than what's called for, just for show.
I have a set of 16" tires and rims off of a 2000 E-250 that I will use on the 77 in the event I intend to use it for work.
CobraGT40
1999 to 2016 Super Duty
03-14-2012 05:36 AM
jmw00
2004 - 2008 F150
10-03-2004 04:53 AM
MrValentine
05-14-2004 07:57 PM
John Helldorfer
08-09-1999 03:15 PM
Quick Reply: 8 lug Ford rims...
