My new truck.
#482
#484
#486
#488
#490
#491
Well here is the status.
My steering is still not right. It is tighter but there is still a side to side slop.
There isn't any leaks so that is good. i took it out for some runs and still only get 15lbs boost. about the same as before. I'm on flat land and the truck seems to haul *** but very concerned after all the stuff I have done I still cant hit 20.
#492
#493
I did not do the up pipes I did inspect them and they were not leaking that I could tell. No soot on the body everything felt tight. I have made a ton of mods with out driving it between them so it could be multiple things. I have not tested the IC. I shutter at the thought of pulling stuff off now. I was looking for notes from when i drove it home but I cant find any about the boost. I remember about 15 but on a hill was 17 or a tad more.
I have changed the turbo wheel to rifraff billet added the IC. other stuff but I don't think it would affect the boost.
#494
#495
https://www.ford-trucks.com/forums/9...ctor-pics.html
I'm sure Travis can explain it better than me .
There are some pics somewhere of fancier leak detectors but I haven't been able to find them. Some guys have tapped in valve stems and pressure gauges.
