07-14 towing mirrors on an 06
I got a very good deal on a set of heated power towing mirrors with puddle lamps and turn signal off of a 13 f150. I was informed that the wiring is only suitable for an 07-14 f150 and that the wiring is the only difference on my 06. I was wondering if anyone could point me in the right direction on this small project? I heard something about the pins on the plug possibly? Thanks
I never did figure out the wiring change required on my 06, so ended up simply plugging them in. Everything worked as far as I could tell, including the turn signals. The only difference was the defrost button indicator light on the dash flashed whenever a turn signal was active. Since it is such an unobtrusive light to begin with I simply lived with it until I traded the truck in.
Though I wasn't able to identify which wires went to what function, I suspect the defroster circuit in the mirror was reversed.
jimbo1969
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-07-2017 06:49 PM
