Thinking of buying one with 240K...am I stupid?
It's a 2011 cargo model with an impressive carfax report...oil changes always on time and always serviced at a Ford dealer. Transmission rebuilt 15k ago.
If I buy this should I plan on replacing the engine right away? I suppose any engine is near it's end with 1/4 million miles on it.
Does anyone know of a trusted source for used low mileage engines?
Your thoughts?
Your thoughts?
Thanks!
Broke;
You pose some interesting questions and Frantz lays out some good beginning considerations.
One consideration that I would want to make, if I was in your situation, is what year engine would you go for? 2014 ushered in two engines with more power than offered previously. I don't know if the newer engines would bolt right in and I don't know how the original transmission would handle the extra power.
As Frantz notes, there are a number of costs to consider and it might be that case that you could spend more money on this high-mileage vehicle than you would on a newer, lower mileage van. Part of the cost would depend on whether you did the work or farmed it out. In terms of a used vehicle, you might want to check the Enterprise rental sales--they will ship.
In any event, I'd want to do a lot of research before I made the jump.
Good luck with your decision making.
I have no doubt the market value is $5k. I have leftovers that I'd sell around $22k. Even if you get a new '16 with less rebates, you're paying about 1/5 the price, but I'd argue you aren't getting 1/5 of the use. Small business is tough, I own one myself I'm trying to get off the ground and I have no new trucks yet. If you have that truck on the road daily you can probably make the higher payments, and in 5 years have no payments and several years of use left. If payments are a concern, a few banks will do 72 months for commercial with no trouble.
Still for 5k, if you put a new motor in it, you'll have what 10k invested? so long as nothing else major happens it might not be hateful. Utility value and market value are different animals. I could go either way, but would lean towards a new unit.
