Official Ford Forum : Ask an Engineer Weekly Q&As with Ford Engineers!
6.2 motor oil change for 2016
Old 02-01-2016, 06:35 AM
don123's Avatar
don123
don123 is offline
It would be better to use 5w 30. But because I have the exact same motor in my 2015 as the 2016's I have to use 5w 20 for the warranty. Very strange.
  #32
Old 02-01-2016, 09:55 AM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
I would think a TSB allowing older 6.2 engines to use the new standard of 5W-30 would take care of the warranty issue.....we'll see...
  #33
Old 04-02-2016, 12:47 PM
condore's Avatar
condore
condore is offline
Oil Weight
In most cases the answer is simple. Manufacturers use the lightest oil they can for average conditions the engine is likely to see. The lighter the oil the higher the gas mileage they can advertise. Almost all modern engines are produced using better alloys and with tighter tolerances than they were years ago. When Ford specifies an oil in the users manual they do not know if the vehicle is going to be sent to Alaska or Florida. Nor do they know if will see its life being used to carry supplies in the bed or be used to constantly pull a heavy trailer. In my case I live in Florida where it gets to the high 90's in the summer and sometimes tow a 6000 lb car trailer and have the AC on. These conditions create more heat and stress on the engine therefore I always go a step up on the weight of oil suggester in the manual. Depending on the vehicle I use either 10w20 or 10w30. Anything with a 5w is best for colder weather
  #34
Old 04-02-2016, 02:28 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
The original question was .. why did switch oil grade in the 2016 for the 6.2L engine..? What you stated is true, but did answer the question.
  #35
Old 04-02-2016, 07:35 PM
dkf's Avatar
dkf
dkf is offline
So in other words.... "We found out we screwed the pooch with our 5w20 recommendation due to higher mileage failures and excessive wear in SD gas engines. But don't switch your current engine that specifies 5w20 to 5w30 (even though we made no changes to the engines) or you will lose your engine warranty."
Sorry that is a bunch of crap.
  #36
Old 04-03-2016, 08:32 AM
Strokin-A-2010's Avatar
Strokin-A-2010
Strokin-A-2010 is offline
Originally Posted by ATP Pilot
here is the chart, looks like the 6.8 changed too.
https://www.fcsdchemicalsandlubrican...f/oilchart.pdf
It actually show the 6.2L and the 6.8L using both 5w20 and 5w30.
  #37
Old 04-03-2016, 09:23 AM
ATP Pilot's Avatar
ATP Pilot
yes, for different year models..i.e. 2016 switches to 5w30...not sure what you are saying ...but you may want to look at the chart again.
  #38
Old 04-03-2016, 09:37 AM
Strokin-A-2010
Doesn't show the years on that chart. So how could someone go off of it?
  #39
Old 04-03-2016, 12:53 PM
condore's Avatar
condore
condore is offline
Oil Weight
For an example, I have a 2015 Mazda3 and the owners manual states the following. "Oil recommendation for USA, Canada and Puerto Rico - Use SAE 0W-20 engine oil. 0W-20 is required to achieve optimum fuel economy." " Except USA, Canada and Puerto Rico Use SAE 5W-30." This statement makes no real sense and I use the heavier oil for better engine protection even if I give up maybe 1/2 MPG. As far as warranties go, if you went into a dealer with a problem there is no way they can tell if you are using a slightly different viscosity than the owners manual calls for. As oil is used in an engine is subject to stress and heat which breaks down the viscosity of oils this can happen slowly or quickly due to conditions. It takes sophisticated equipment to produce and determine viscosity and is only useful in testing NEW oil. Oil analysis is sometimes used by fleets to determine the maximum life or change intervals of different oils but is not used to determine viscosity.
Just some things to think about.
  #40
Old 04-03-2016, 02:31 PM
Snowbirds11b's Avatar
Snowbirds11b
Snowbirds11b is offline
What I understand is Ford will keep their position for lawsuit in case of engin failure after warranty on previous years !
  #41
Old 04-03-2016, 07:46 PM
ATP Pilot's Avatar
ATP Pilot
yes it does show the years across the top
  #42
Old 04-03-2016, 07:51 PM
Strokin-A-2010
Sorry was looking at it originally on my phone. Now that I'm on my laptop and I read it better. My apologies.
  #43
Old 04-09-2016, 08:24 AM
yeslekb's Avatar
yeslekb
yeslekb is offline
I have a 2011 super duty w/ 6.2 flex fuel. When shifting into reverse, it hesitates, then slams into reverse. Also hesitates between gears while shifting up, mostly lower gears. This doesn't happen all the time but prob 90 % of the time. Talking to other super duty owners (diesel trucks) are noticing the same. Issues seem to have started after having charcoal filter replaced. Any ideas out there? I know this is off topic, but would appreciate all the help I can get. Thanks
  #44
Old 04-12-2016, 04:35 PM
Ford Trucks's Avatar
Ford Trucks
Ford Trucks is offline
Official Ford Trucks
Thanks for asking yeslekb but our engineers can't answer those types of questions. You might want to check the discussions in the Super Duty thread section since, like you said, other folks have experienced it too and see what they've done to fix it.
  #45
Old 06-29-2016, 07:38 PM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
5w-30 rules
I have used 5w-30 oil from day one. Mobil 1 extended service oil. Gets hot here in Texas. 342,000 miles,no major issues. Hot shot rig. No blowbye. Ford 820s filters
Have no fear.......
Quick Reply: 6.2 motor oil change for 2016
