Yes I did. The only connectors in the entire truck I did not replace are for the courtesy lights and the column plug. Everything else is now Weatherpack.
I'll tell you it was a ton of work, but worth it. Removing components is now a snap. No worry about breaking this or that tab, or having one that is glue together by corrosion and time. Also if you manage to mangle a connector it's a 1 minute job to replace the connector body.
