2000 Ford Expedition v8 p300 code
I have multiple codes that have shown up, a little history, I purchased vehicle in Atlanta and now am in Colorado @ 6600'
P300 shows up. At idle it hunts and misses but at higher rpm's I do not notice any loss of power.
P1131 and p1151 lack of ho2s switch sensor indicates lean.
Are these 3 codes related and where should I start?
Any help appreciated
Thanks guys.
Thanks guys.
Since the problem is occurring mainly at idle and then disappears at higher rpms indicates there may be a vacuum leak allowing unmetered air to enter the engine and cause the lean condition. This affects the air/fuel mixture and could result in the random misfire code as well.
I would suggest looking around the engine bay for vacuum leaks; check for any loose/damaged hoses or vacuum lines, or any cracks in the intake tube past the MAF, anywhere there could be a loss of vacuum. You could also check for leaks by spraying some throttle cleaner near hoses and intake manifold and listening for a change in rpm.
Stacy Lynn
1997-2006 Expedition & Navigator
03-07-2018 02:52 PM
