My 69 f100 pig-pen build
#272
Just found a pic.
#274
#275
on
Thanks Mike, I will do that... after slapping my forehead several times... like Duh?? Hello in there?? I will have to cut the hole in the top of the tank for the sender, but I have full access to it, so not a problem... The FG is thick, like at least 1/4", so the self tappers and a good gasket might do the trick, plus a thin coat of silicone.
I will post some photos as I progress....
Baja
Baja
#276
on
I have a friend who added a larger tank in his truck and use the red rtv silicone on the sender and guess he used way to much as some dripped down into the tank that got sucked up into the pickup tube that caused him some programs for a while.
I guess he did not have a filter sock on the pickup pipe in the bigger tank..
Some rtv silicone should not be used as a sealer with gas passing through it..
Orich
Orich
#277
on
Good advice Rich... thanks from me, and many a reader I'll bet. I see the 'Blue Goo' and the Yellow Death, used in excess on valve cover gaskets all the time... If some is good, more is not always good... I have the red, blue, and yellow silicone, with the red being high temp... I also have some 'Forma gasket' brown, which may be good for gas fumes. I will look for some specifically used in gasoline applications... thanks again amigo...
Baja
Baja
#281
#282
#285
How 'bout one of these? FRPP part number M9600P302
Shopping Cart
Order Status
Email Sign-Up
Home > 1965 - 1973 Mustangs > Air/Fuel
Air/Fuel
AIR CLEANER ASSEMBLY HI-PO STYLE 65/73 V8 (FRPP)
Mouse Over image to Zoom in.
Click image to see complete image.
AIR CLEANER ASSEMBLY HI-PO STYLE 65/73 V8 (FRPP) Ford Racing Chrome Air Cleaner Assembly Hi-Po Style for 1965-1973 Mustang.
14" diameter, round OEM-style, chrome, fits single 2V & 4V carburetors. Standard Chrome Wing Nut & threaded rod included. Features correct white paper 2-1/4" tall filter element. The steel base features a blue powdercoated finish.
Measurements:
-Mounting flange: 5-1/8" dia.
-Net height from carb flange: 3-1/4"
-Dropped Distance: 1/8"
Related Parts:
-Motorcraft Air Cleaner Element, #FA41
-Air Cleaner Decal, 289 Hi-Po, #DF15
Item No: M9600P302 01 Our Low Price: $26.95
Email product information to a friend.
