Loud whine, no boost.
The high pressure turbo on my 08 went out during summer. I bought a set of Industrial injection turbos, and did the replacement cab on in the driveway.
It ran fine once it was all back together. Then about a week ago on the way home from work I noticed a howling noise starting. By the time I got the truck into the driveway I had lost all boost and the noise was really loud.
No noise at idle, but when power braked it comes back, and am getting no boost at all.
Did my new turbos just go bad? Or is it maybe an exhaust leak somewhere?
I checked all the up-pipe connections and couldn't feel any leaks anywhere, no soot on firewall etc. Turbo actuator is cycling...
Finally got it torn apart again. Hi pressure impeller had FOD damage, not sure from what as the low pressure had no signs of ingesting anything. In the process of putting them back in. I need the spongey gasket that is between the fuel cooler and turbo connection, can't find anything about it online? anybody know the part number or what it is called ?
Thanks,
Chris
Thanks,
Chris
Mr. Andrew
04-19-2010 06:01 PM
WideOpenFord
40
01-11-2010 04:21 AM
fuelboy001
11-19-2009 06:57 PM
