Grumps 72 F100 Build
#37
It's been awhile since I posted any updates, but the winter weather has slowed my progress. So I thought I'd catch everybody up on my project.
Here the Crown Vic suspension is located and the mounting bolts installed.
A little frame clean up is in order, with the angle grinder and a cup brush.<br/>
The rear suspension mount all welded up, almost ready for some por-15.
All cleaned up with a nice coat of por-15
Suspension all installed.
#38
Installing a 1969 Mustang betweenn the frame rails. made s support out of square tubing.
Tight fit .
Motor mounts for the 460 installed on the suspension cradle.
Mounted up to the block and welded up.<br/>
Brake lines installed.
Really starting to look like something.
Got the Lokar Parking Brake Cable all mounted up, nice set up.
Nice sunny day to see what it looks like in the sun.<br/>
#40
Now that the chassis is all good, time to start on the body. A trip to the sand blaster will get it all started.
Looks like I have at least one cab corner to replace and of course the drivers floor pan.
Marked out my first cut.
Well that was no fun at all.
All welded up.
Aft part of the bed cut and clamped together, ready for some welding.
Starting to look like a truck.
#41
#44
#45
Haven't got around to the cab yet, but it's on the agenda. The gas door assembly is from Hagan you can see it here 90 Series Round Flat Fuel Door.
theastronaut
601
04-02-2019 03:21 PM
Brad sxt
01-06-2017 01:54 PM
farmall_7
01-13-2016 01:13 PM
Hobby welder
02-07-2015 06:44 AM
e-tek
217
04-07-2014 12:13 AM
