05 axle swap and some wheel questions
#47
#48
#49
I haven't gotten around to installing my leaf springs yet, but it shouldn't take much work to get them in there. You may have to ream out the bolt hole in the front hanger a little bit and on the rear shackle you can use the factory one, you just might have to cut out a little bit of the shackle to make more space for the spring.. I'm not sure if the '07 shackle will fit our trucks or not. If you use your factory shackle, you might want to change the shackle bushings while it's apart.
#50
#52
#53
Well got my rear springs in ended up just using my original main leaf and all the new leafs and installing my axle pinion shim rides better now I'll get pics tomorrow just gotta install overload stops and rear sway bar and also the front stabilizer shock and new steering shock and I'll be done
#55
#57
on
1 Post
#58
#59
#60
<img src="https://cimg5.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/80-img_0986_68382a39234c48184205447947fa6a268b880d14. jpg"/><br /><img src="http://cimg6.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/720x1280/80-img_1003_cdeb8d6a997bab1db7083f4fc5a3329f2aabb244. jpg"/><br /><img src="http://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/720x1280/80-img_1028_b16c2893860781e80620007f0ee7eed25b0ead5b. jpg"/><br />He is a 6.0 driver thought so he may be a bit off but I half to admit it's amazing how u can drop a sct with some custom tunes on a 6.0 and it totally changes things there ignorant his is stupid quick but I still wouldn't trade mine for one I just don't trust them and I like obs better anyway but check out the headlights we built for him they have the color changing strips in them
