1955 F100... I call her Reece.
#31
The holley 500 2 barrel is what I have on my 268 flathead, some say it's too much for it also. I had to adjust the accelerator pump ramp, and you may need to set the throttle so it doesn't open 100% , just keep checking you plug colour after every adjustment until they are nice brown. Cheers.
Anyone have experience with overdrives? The 3 speed on the tree has overdrive, but is not working correctly. It feels like it is stuck in OD, because when I coast in 2nd and 3rd gear, I have zero engine brake. When pulling the OD cable, does that disengage the OD? Any tips on repair?
#32
#33
Our vendors like MidFifty, Macs, Dennis Carpenter, LMC all offer many parts.
Regular auto parts stores carry a lot of stuff as well.
The gasket set from FelPro is FS 7999 PT-3
That is available at most parts stores.
Fel-Pro FS7999PT3 - Full Gasket Set | O'Reilly Auto Parts
Felpro Full Gasket Set FS 7999 PT-3: Advance Auto Parts
NAPA AUTO PARTS
NAPA AUTO PARTS
#35
NAPA AUTO PARTS
NAPA AUTO PARTS
Thanks for the links Harrier! I ordered through Advance Auto Parts, I don't have a local store, but I couldn't pass up the 20% off and free shipping over $75 orders.
Try this post. https://www.ford-trucks.com/forums/6...sion-work.html
#36
So in January, I took my truck to the gas station for the first time since buying it in November. On my way home, I wanted to see what her top speed was. Long story short, I blew a diaphragm in the carburetor. It started leaking and all kinds of idling issues started. I ordered the rebuild kit in February and the truck sat for 2 months. Last night I finally built up the confidence to tackle the job. This was my first time rebuilding a carburetor and I gotta say it was pretty straight forward. I took a couple of pictures of the dis-assembly in case I forgot how to reassemble it back. The model Holley carb I had didn't use all the parts that came in the kit, so that made me feel a little worried I didn't dig far enough into it, but I've read somewhere that's normal to have extra parts. Took me roughly 5 hours from removing it from the motor and reinstalling back on the motor.
Carb ready for the rebuild.
All the parts in the kit. The green gasket looking thing is what was casing my leaks. It was hard and cracked.
Knee deep in the rebuild.
Idles way better now and even the wife noticed too!
#37
Back to the engine size for a minute. You established that you have an EBV 239 block and a late 50s intake manifold. Go the next step and pull the value covers off to determine which heads are on the truck. Look for that 3 letter code stamped near the rockers.
239 overhead V8 engines were only used in 54 and 55, then the 272 and 292 become the primary production engine for Ford. Unfortunately, many of the 272 and 292 parts do not fit on the 239. Know that a 256 (EBY) was also used in Mercury autos and those parts do interchange with the 239. Many of the 239 parts interchange between cars and trucks, but certainly not all parts.
Also, the water ports on the late 50s intake manifold may not match exactly with 239 heads. This can cause a cooling problem - engine running hot may be a symptom of this.
#39
Congratulations on the purchase of one beautiful truck and welcome to the forum.
One of the questions you asked was concerning the OD transmission. I owned a 49 Ford Custom Coupe that had 3 speed OD and I loved how it worked.
Here's a little article that might help you in it's operation-
The Borg-Warner Overdrive Transmission Explained- FORDification.com
#40
I have no plans to replace the motor any time soon, so I'm keeping the 239 until I hit the lottery or the wife gives me a blank check. Whichever comes first.
I've driven the truck to work through the back roads and sat at a few stoplights. That was a 30 minute commute and it didn't seem to overheat.
I'm planning to refresh the motor when I pull it to do my IFS install. When I do, I want to upgrade the cam. If it is up-gradable, what CAM do you recommend for the 239?
#41
#43
Good job fixing the carb. Nothing like a sense of accomplishment when you repair small projects on these classics.
#44
Thanks for the kind words! Yeah when the truck fired up and idled smooth, I was on cloud 9 for sure!!!
#45
