35's with a level and flares
#76
So you guys with the 35's, flares and a level... Are you having any rubbing issues? I have 35x12.5 Toyo MT's on -24 offset rims and I am already rubbing on the inside with no flares. I was going to add another inch to the front (currently at 2.5" and would go to 3.5") but I don't think that's going to cut it. Thoughts?
#77
Yep I'd bet its prolly those -24 offsets that are doing it.
BTW Irish I've got all the stuff to lower mine, if you still want the 6" stuff it will be minimal and shipping, I wont need the stuff any more and it will just sit around...
#78
Where are you located? I'm in Canada...
#79
No problem ako... I just saw your response
So it looks like they are real bolt ons instead of taped on!? That's OK by me, If there is another owner ever they will worry about the drilled fenders, doesn't bother me one bit...lol.
Thank you sir...
Thank you sir...
#80
#81
I have the 3.5" readylift SST so I'm halfway to the readylift 5" or 6" lift kit. Just need to decide which I'm going to go with. As it stands, I likely will go with the 6.5" kit.
#82
I already have the radius arm drop bracket and spacer for the lower shock mount.
This will get replaced with a proper spring.
This will allow me to use the front 4-5.5" lift fox 2.0 shocks I bought.
This is the kit I already have.
And as you can see here, I already have almost everything. Just need the springs and a few other odds and ends.
#85
I have since replaced that with a all spring 6.5 inch lift. 😁
#86
#87
#88
How much you want for it PM me or if your giving it to me and I pay shipping then sweet I'll take it
#89
What do you want sorry let's go ahead and work offline through private message hit me up I'll be waiting.
#90
